PXI
PXI-1033 Express PCI
I switched my laptop recently to Lenovo ThinkPad and since then the new laptop does not recognizes the NI PXI-1033.
The chassis two LEDs are green, I have installed the BIOS compatibility configuration software and the mode is set to ON, and all of the software and drivers are up-to-date. But still the Device Manager is marking the PCI-to-PCI bridge with yellow exclamation mark, with the error code of 31. The detail of my system and the problem is captured in the following image. I will appreciate any help to resolve this issue.
(5,672 Views)
This other forum post seemed to have a similar issue.  There wasn't a solution, but there were some good troubleshooting steps thrown out and one of them might be a solution for you.
http://forums.ni.com/t5/VXI-and-VME/Error-code-31-Drivers-will-not-install-correctly/m-p/900953
Also, this KB goes through some BIOS troubleshooting steps which may be helpful in this case.
http://digital.ni.com/public.nsf/allkb/BF84B75E08D2A7708625763B00670007
Finally, since this is a laptop, are you using a PCIe slot or a ExpressCard slot?
-Jim
-Jim B
Applications Engineer, National Instruments
CLD, CTD
(5,619 Views)
