PXI
PXI-1033 chassis does not turn on
i'm new here and i hope i can get some answers here.
i'm working with several PXI-1033 chassis and one of them i'm not able to turn on.
During all night , system was turned off. and in a morning it dead. everything is powered on. but all lights on CHASSIS is off. I noticed that red LED blinks once whenpower button is on, and i disconnect a power cable.
yesterday i had same issue, but i hold chassis  disconnected from rest of system about 20 min  (was cleaning a fan filter) and it started to work normally for rest of a day.
Maybe some one  was facing same issue?
(3,126 Views)
Hi.
You can try to disconnect the chassis from the power for a couple of minutes, maybe that could "reset" some internal things.
The fans work properly?
Regards
(3,093 Views)
helped only if i  wait for about 30 min and disconnect 2 cables (power and data) from chassis.
after that chassis button become orange and link indicator blinks green (still was not working) but after couple of min it started to work normally.
(3,088 Views)
And at this time os working fine? Or you had the same behavior again?
(3,068 Views)
its every time if system is turned off.
(3,064 Views)
