PXI
PXI-1033
The PXI-1033 was working without any issues and powered down normally. Now the PXI-1033 does not switch on. The PWR light does not illuminate and the fan is not operating. How can I troubleshoot this issue please? The power supply shows no sign of powering up.
(1,656 Views)
I disassembled the unit, but found nothing serviceable - the power supply could, though, be easily replaced if the part is available. There are some PXI-1033 available on line for spares.
(1,593 Views)
Based on the user manual troubleshooting tips, Power Supply could be dead.
I would recommend reaching out to NI Support to check if you can purchase a replacement power supply to fix it yourself or you can send the chassis to NI for repair.
Santhosh
Soliton Technologies
(1,582 Views)
