PXI
PXI-1044 - Problem with analogue input climbing to 10 volts.
I have a NI PXI-1044 containing the following cards:
PXI-6225
PXI-6704
PXI-6511
PXI-6515
I have sensors connected and can read a steady voltage but sometimes the voltage starts climbing to 10 volts. The only way to get it to read the corect steady voltage is to put a volt meter accross the terminals.
Does anyone know what is going on?
If you need more information please ask.
(2,436 Views)
Start by reading this article: Field Wiring and Noise Considerations for Analog Signals
GCentral
(2,424 Views)
