PXI
PXI 1045 does not fit in a rack
The NI PXI 1045 does not fit in a standard 19" E.I.A. rack (Agilent).
(3,615 Views)
Constantine,
I assume you purchased the optional front and rear rack-mount kit? If so, what dimension is giving you problems? Is it the width, the height, etc? More information would make it easier to help.
Tyler S.
(3,602 Views)
Yes, the optional front and rear rack-mount kit was purchased. It is the width that is the problem. It is too wide to fit in the 19" EIA rack enclosure.
(3,597 Views)
