08-29-2007 08:37 PM
08-30-2007 05:00 PM
08-30-2007 05:40 PM
Hi Nick,
Thanks for your reply. The error that I am experiencing is happening AFTER I set up the trigger routing in MAX. Without the routing, things work when on the same bus. So at least I know that my code and chassis configuration are correct. The problem is that once I set up the trigger routing to connect the triggers across the busses, I get the error -89125.
Cherie
08-31-2007 05:46 PM
09-06-2007 09:01 AM
09-06-2007 11:18 AM
Thanks Nick. That helped. Now I understand how this is supposed to work.
Cherie
09-25-2008 09:50 AM
Is it possible leave the PXI Triggers Lines configured to be routed dynamically in MAX, and then programmatically in LabVIEW configure them to be "Away from Slot 1", "Outwards from Middle", or "Towards Slot 1"?
Kevin
09-26-2008 10:36 AM
Hi Kevin,
Try looking at the bottom of this KnowledgeBase as it may be what you're looking for.
KB 3TJDOND8: Using PXI Timing and Triggering Functionality
http://digital.ni.com/public.nsf/websearch/BD37A128B1DF27F3862570FC0072359D?OpenDocument
11-20-2009 03:41 PM
