PXI
PXI 1050 chassie without a controller module installed
Please any advice with using the PXI 1050 chasse without any controller module installed, so I will use the PXI 8231 network module and a pc and instead.
Thanks.
(3,933 Views)
Hello decay,
It appears you have a PXI 1050 chassis without a PXI controller.  You will therefore need to use a MXI link between the PC and slot 1 of the chassis. The chassis will then appear as an extension of your PC's PCI bus.
Do you have a specific question about your hardware?
Regards
George T.
Senior Applications Engineer
National Instruments UK and Ireland
(3,918 Views)
