PXI
PXI-2503 Relay's
Hi
knows anyone the related K-Relay Numbers of the CHannels- Relais? I can't find it in the documentation.
Thx
Wolfgang
Message 1 of 10
(5,346 Views)
Dear Packmers,
could you please explain what you exactly mean by the "related K-Relay Numbers" and what you need to for.
Kind Regards,
SG3 | Staff Applications Engineering | National Instruments | NIG |
Message 2 of 10
(5,329 Views)
The Relais on the 2503-Board are only numbered from K0...K31.
Message 3 of 10
(5,326 Views)
Dear Packmers,
Here you can find the Pinouts and the Hardware diagram for the NI PXI-2503.
NI PXI-2503 Specifications
Kind Regards,
Message 4 of 10
(5,324 Views)
But what is missing in this Specification is the Relais Number (K0..31) or is it in the chinese Part Smiley Wink?
Message 5 of 10
(5,319 Views)
Dear Packmers,
where are you seeing this Relais Numbers (K0..31)?
When I'm looking into my MAX into the config of the PXIe-2503 I am seeing this:
There are the same channel numbers (ch1..ch23) like in the Specs.
So please give me more information.
Kind Regards,
Message 6 of 10
(5,309 Views)
I see the K0..31 Numbering on the Hardware-Board of the 2503. I need to replace some Relais- o.k. I could measure them out, but easier would be a reference to the Channels.
Message 7 of 10
(5,307 Views)
Dear Packmers,
usually the deployment of broken Relays is done by our RMA service because if you do it on your own the warranty becomes invalid.
And this is why this information is not in the Specs because we don't expect the customer to do any modifications on the HW by his own.
I would command you to RMA the HW and get the Relays replaced and the HW tested.
Kind Regards,
Message 8 of 10
(5,302 Views)
Thats strange, because for the more difficult to repair 2532 an Instruction for repair the card by customer is available.
So it looks, i have to measure it out.
Wolfgang
Message 9 of 10
(5,297 Views)
Accepted by topic author Packmers
Finaly I've make the work to measure the relays by hand:
K0..23 =CH0..23
K24 = BC01
K25 = BC23
K26 = BC02
K27 = CJS
K28 = 1WIRE
K29 = HISELECT
K30 = AB0
K31 = AB1
Message 10 of 10
(5,219 Views)
