PXI
PXI-4060 incompatibility with Vista
I have a PXI controller with Vista installed. I am having trouble getting a PXI-4060 to work/install properly.
What version of NI-DAQ should I be using?
Should I be using a different software?
What kind of work around is there to get this card working properly with Vista?
Thanks!
(3,286 Views)
Hey reichenbach,
The PXI-4060 is not supported in Windows Vista. In order to use this card you will need Windows XP/2000. This information can be found in the NI-DMM readme. A good replacement that will work in Windows Vista is the PXI-4065.
The driver you would need for either operating system is the NI-DMM driver.  The newest version is 2.8 and can be found here. Let me know if you have any questions and take care.
Nathan
NI Chief Hardware Engineer
(3,270 Views)
