PXI
PXI 4065 resistance measurement via backplane
I can't seem to find a manual for the 4065. As such I am posting my question here.
Is it possible to measure resistance using the 4065 using the PXI chassis backplane via switches?  For example 4065 would be on slot 2 and an NI switch would be on slot 3. The NI switch would be connected to a UUT.
thanks in advance,
Jose
(2,420 Views)
Hi Jose,
Typically you would connect the 4065 to a row of the switch and then measure by connecting the DUTs through the columns to the row with the device.
Is there a reason you need to do it via the backplane?
The manual will be installed in LabVIEW when you install NI DMM in the help menu!
Chase
NI Technical Support Engineer
(2,392 Views)
