PXI
PXI-4462 actual sample rate and delay...
Hi All!
Is the DAQmx properties, which give me actual sample rate and filter delay? Or I must manualy calculate this values, as described in DSA manual?
Jury
(5,200 Views)
Hi Jury,
I am not sure if I fully understand your question, but there are DAQmx properties that do return the actual sample rate, but there is not one for filter delay. If you place a DAQmx Timing property node down, the actual sample rate will be returned by selecting Sample Clock » Rate.
Jason D
(5,172 Views)
