PXI
PXI-5105 Minimum Voltage Range
I searched the forums for this question but did not get a concrete answer.  I'm using a Kulite ITQ-1000 pressure transducer attached to a RDP signal conditioner/amplifier which is then fed into the PXI-5105.  The signal has been set so that the maximum rated pressure outputs +10V from the RDP unit.  My question is regarding the minimum voltage level...  I noticed on the specifications for the 5105 that there is a "Minimum Voltage Range" of -25mV,25mV.  Does this mean that the minimum voltage input that should be fed into the 5105 should be no less than, in my case of only positive voltage, 25mV?
Ryan
(3,331 Views)
Nevermind... I figured it out
(3,310 Views)
