PXI
PXI-5105 Triggering with an external source on channel PFI1
HI, I am trying to trigger my acquisition from a function generator into the PFI1 channel on the PXI-5105 in LabVIEW. I am configuring the trigger using the niScope Configure Trigger Edge.vi and choosing "External TRIG" as the channel.  In my code I receive an error at the niScope Actual Num Wfms.vi. The error displays "Source terminal could not be found on the device" if I choose Digital Edge on the configure trigger vi and displays "Invalid value for parameter or property. Property: Trigger Source Invalid Value: TRIG" if I choose Analog edge on the configure trigger vi.  I am able to trigger on any of the 8 RTSI channels without problem but I was hoping there was a way to trigger on the PFI1 channel.
Do I need to configure the PFI1 channel before using the configure trigger vi? If so, how do I configure the PFI1 channel?
OR
Is there a better way to configure the trigger besides using the configure trigger vi?
(5,613 Views)
You should be able to use the PFI line to trigger with the 5105 by specifying PFI 1 on the input to the scope trigger VI.  Note that the available trigger channels does not update when you change the trigger type.  For example, if you create a constant/control on the trigger terminal input and then change the trigger type to digital from analog you will need to recreate the control/constant to get the updated list of available channels.
James K.
(5,594 Views)
