PXI
PXI-5114 Vertical Range
As for PXI-5114, is it possible to set different vertical ranges to different channels?
For example, I would like to set 1V as a vertical range for Ch0 and 5V for Ch1.
I've confirmed some sample VIs, but in the sample VIs, only one value is assigned to a vertical range for both channels.
(2,806 Views)
What sample are you looking at?
Are they in NI Sample Finder?
(2,777 Views)
Accepted by topic author MasakiIshiguro
Thank you for replying!
I made the same question in Japanese Discussion Forums and the issue has been solved.
Please find the link below.
https://forums.ni.com/t5/NI%E8%A3%BD%E5%93%81%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AB%E3%83%83%E3%82%B7%...
Thanks!
Ishiguro
(2,772 Views)
Glad to hear!
(2,768 Views)
