10-05-2011 03:49 PM
hello. i am trying to do a measurement on a rfid signal.
and i would like to know how i can set a trigger to acquire the data from the rfid tag when it response to the reader.
the rfid tag is connected to the pxi 5122. software that is used is LabWindows/CVI and NI-DAQmx.
regards
10-07-2011 09:42 AM
The 5122 is not really supported under the DAQmx API. The NI High-Speed Digitizers have their own IVI-compliant API called NI-SCOPE. You can download the driver here:
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du,ssnav:sup/q/scope/
Also, it should have come on CDs packaged with your hardware.
There is an NI-SCOPE example, called ConfiguredAcquisition, that demonstrates exactly what you want to do. NI-SCOPE also contains comprehensive documentation for the 5122, from both a hardware and software perspective, which you will not find in the DAQmx API.
10-19-2011 03:50 PM
with this example i will be able to export my data in some file format so i can process them in MatLab or any other program?
10-20-2011 10:57 AM
NI-Scope is the driver that would be used in the programming environment, such as LabVIEW or in your case LabWindows/CVI. Those environments would handle the File I/O.
Typically, the data should be formatted in a TDMS or TDM file format, but other formats such as ASCII are supported.
Here is a link to a TDM example:
MATLAB®-TDM-Example User Guide
