PXI
PXI-5620 Cal Exec Error
Error occurred at:  niScope Multi Read Cluster.vi
<err>Driver Status:  (Hex 0xBFFA4001)
I have reloaded all of the newest drivers, but the procedure won't get started. Any ideas??
(3,201 Views)
Is this error still an issue?  I am interested to know what versions of NI-DAQmx, NI-DAQ, and NI-Scope are installed in the system.  This error might be caused by a bad installation of a driver.  I also looks like it will be worth some time to also test the device in Measurement and Automation Explorer (MAX) to see if it passes a self test.
Samantha
(3,159 Views)
