PXI
PXI-5620, PXI-4351 on Windows 7 64-bit
We are trying to use a PXI-1045 chassis with Windows 7 64-bit. All cards are working except for PXI-5620 (digitizer) and PXI-4351 (temp/voltage). It seems both of these cards do not work on a 64-bit OS. Is there any newer models of these cards that work with 64-bit and are supported by the PXI-1045?
(3,572 Views)
Looking in the NI-Scope 15.1.1 Readme, it looks like you’re right; the PXI-5620 is not supported under Windows 7 64-bit. The only PXI-56XX card that is supported is the PXIe-5622, but this will unfortunately not fit the PXI-1045 form factor. You might browse the Readme below for other available options.
http://download.ni.com/support/softlib//high_speed_digitizers/niscope/windows/15.1.1/readme.htm
As far as the PXI-4351 goes, it looks to only be supported by Traditional NI-DAQ (no Windows 7 support). The upgrade for this hardware is the PXIe-4353 (supported by DAQmx 15.5, which is supported by Windows 7 64-bit), but we would again run into the same problem.
NI-DAQmx 15.5 Readme
http://www.ni.com/pdf/manuals/374768h.html
It looks like there are upgrades available, but the PXI-1045 is unfortunately acting as a limiting factor.
Ross S.
Applications Engineering
(3,535 Views)
