PXI
PXI 5660 not listed in DAQmx after creating VISA resource names with the VISA wizard.
Dear all,
I'm using 4 PXI cards 5600,5620,5610 and 5441 on a Win XP computer with labview 8.6.
I need to use the RFSA module in labView. this module works with the 5600 (dowconverter)and 5620 (digitizer). and all the VIs in Labview are created for the 5660 module.
When I  installed all the devices driver and the different modules software, everything was fine in MAX.
When i started working with the different available VIs, I have seen that a VISA resource name was often needed.
So using the provided help files, I added the devices in the VISA wizard and they are now available in the  "VISA  Interactive control" window.
Once i had done this, the 5660 module disapeared from the DAQmx devices list in MAX and  I can't get it back even with uninstalling everything.
Of course all Vis that were using the DAQ devices are not working anymore..
Do you have any solutions for this matter.
thank you in advance.
(3,360 Views)
