PXI
PXI-6133 counting signals on PFI0
this may be trivial, but I can not find a hint or figure out the issue. I am using PXI-6133 with the BNC-2110 connector and NIDAQmx. I have a TTL signal on TRIGGER/COUNTER PFI0/P1.0 BNC connector of the BNC-2110. I can count the signals using DAQmxTestPannels dtp.png
I can not figure out how to write a code to do the counting. The example provided with the NIDAQmx base does not count and shows 0. Here is the code I am using
#include <stdio.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int main(void)
	int         error=0;
	TaskHandle  taskHandle=0;
	uInt32      data;
	char        errBuff[2048]={'\0'};
	// DAQmx Configure Code
	DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
	DAQmxErrChk (DAQmxCreateCICountEdgesChan(taskHandle,"/Dev2/ctr0","",DAQmx_Val_Rising,0,DAQmx_Val_CountUp));
	//	DAQmxGetCICountEdgesTerm(taskHandle,"/Dev2/pfi0",data,1);
	// DAQmx Start Code
	DAQmxErrChk (DAQmxStartTask(taskHandle));
	printf("Continuously polling. Press Ctrl+C to interrupt\n");
	while( 1 ) {
		// DAQmx Read Code
		DAQmxErrChk (DAQmxReadCounterScalarU32(taskHandle,10.0,&data,NULL));
		printf("\rCount: %d",data);
		fflush(stdout);
Error:
	puts("");
	if( DAQmxFailed(error) )
		DAQmxGetExtendedErrorInfo(errBuff,2048);
	if( taskHandle!=0 ) {
		// DAQmx Stop Code
		DAQmxStopTask(taskHandle);
		DAQmxClearTask(taskHandle);
		printf("DAQmx Error: %s\n",errBuff);
	printf("End of program, press Enter key to quit\n");
	getchar();
	return 0;
 The output is
.[nidaq@nidaq CntDigEvents]$ ./CntDigEv
Count: 0
Count: 0^C
If I change /Dev2/ctr0 to /Dev2/pfi0 I am getting
DAQmx Error: Physical channel specified does not exist on this device.
Refer to the documentation for channels available on this device.
Device: Dev2
Physical Channel Name: pfi0
Task Name: _unnamedTask<0>
Status Code: -200170
Any help will be higly appreciated. Best regards,
KS
(5,428 Views)
Hi krisXX,
There are some things that I would like to know before:
* What programming environmet are you using to generate the task?
* What OS are you using?
* Which driver versions you have installed?
* Which pins you have connected to your connector block?
The error you get when you change the Dev2/ctr0 to Dev2/PFI0 is because that function will search for the phisical channel of the counter and when you set PFI0 (AI Start Trigger pin) you are assigning a counter channel that will not be available to be selected.
Sil.VI
(5,393 Views)
Hello S.J.
Thank you very much for responding. Here are answers to your questions:
- I am using a gcc ver 4.4.7  on a linux kernel 2.6.32-358.18.1.el6.i686
- I am using Scientific Linux 5
-  I am using nidaqmx version 8.0.2
- I am connecting a TTL signal on the PFI0/P1.0  BNC connector at the TRIGGER/COUNTER part of the BNC-2110, the region labeled as 6 in Figure 2, page 3 of the BNC-2110 manual, below the DIGITAL AND TIMING I/O. I can use this signal as a trigger calling /Dev2/PFI0 , but I am not able to use it as a counter.
Kris
(5,387 Views)
I need to correct the SL version, I am using Scientific Linux 6, but I think the kernel version plays the more important role than the distribution
Kris
(5,385 Views)
Hi krisXX,
I was checking at the compatibility between the software you have installed on your computer, and in the following document you can find that the version of Linux Scientific 6 is supported by NI and the DAQmx Base version that you have installed, and it is listed as a previously supported software, which does not mean that it is not going to work but NI does not actively validate perviously supported Linux distributions. Additionally that version of DAQmx (8.0.2) was supported for Linux Red Hat Enterprise Linux Desktop + Workstation 5
Red Hat Enterprise WS 4 and OpenSUSE 11.1, 11.2, 11.3.
So my next recommendation since the counting was possible using the Test Panel, you may check if you have the correct NI-KAL version installed corresponding to your DAQmx driver. The following link on "Previous Support" section you can find a more detailed explanation and a link to the NI-KAL compatibility table
http://digital.ni.com/public.nsf/allkb/4857A755082E9E228625778900709661
Sil.VI
(5,361 Views)
