PXI
PXI 6133S
The card PXI-6133S in PXI1042 with PXI-8335 controller doesn't work (MAX 3.0 don't see it). I have DAQ Drivers release 7.0 for LabVIEW 7.0. Have to I install DAQ 8.5? Can I continue to work with LabVIEW 7.0 if I install DAQ 8.5?
(3,828 Views)
Hi Enyspring,
the PXI 6133 works only with DAQmx driver family. The version of such drivers that can be still used with LabVIEW 7.0 is the 8.1; here's the NI website download link:
NI-DAQmx 8.1 - Windows 2000/XP
Later DAQmx versions (from 8.3) require LaVIEW 7.1 or later.
Hope this helps,
Fabio
Fabio M.
NI
Principal Engineer
(3,812 Views)
Thanks Fabio,
with DAQmx 8.1and LabVIEW 7 the problem is solved.
Bye, Enrico
(3,804 Views)
