PXI
PXI 6255 Input Time Constant
I am connecting a somewhat large resistance to the input of a PXI 6255 card, and I'm worried about the time constant at the input possibly being too large. What I'd like to know is what is the input capacitance of the card, or at the least, what is the time constant for my setup? I'm currently using about 200kOhms, and it really couldn't get much lower.  Thanks.
(5,955 Views)
Accepted by topic author kyh637
Hi kyh637
NI 6255 Specifications
https://www.ni.com/docs/en-US/bundle/pci-pxi-usb-6255-specs/page/specs.html
In the specs is mentioned that the impedance between AI+ and AI GND is >100 GOhms in parallel with 100 pF.  So, the input capacitance should be 100 pF.
The reason you might want to know this is to determine settling time, I assume.  If so, there are settling graphs on page 2 of the same specifications document.
Cheers!
Fabián M.
Internal Sales Engineer
(5,926 Views)
