PXI
PXI-6255 to SCB-68 Connector Block?
I'm basically a software person and have been given a PXI system that has a PXI-6255 Analog/Digital card. I've also been given a SCB-68 connector block to interface with it. The manual for the SCB (NI SCB-68 User Guide (320745b)) lists wiring reference labels in Appendix B.
None seem to reference the PXI-6255  board. What is listed is:
    * E Series Devices
    * NI 670x Devices
    * NI 671x/673x Devices
    * S Series Devices
    * NI-660x Devices
    * NI 653x Devices
    * NI 7811R/7831R Devices
The datasheet for the PXI-6255 suggests the SCB-68 as an option. How do I determine which of these wiring labels to use?
Doug Wendelboe
(4,296 Views)
Additional Information: I see from some comments in example code that the PXI-6255 is an "M" Series device. So again, the M Series is not included in the list in the manual for the SCB-68 connector block.
(4,293 Views)
You are correct the Quick Reference Labels for the SCB-68 are not listed for the M series in the manual, however a KnowledgeBase has been created since not every quick reference label can be in the manual.  Please view the PDF files titled SCB-68 M Series conn 0.pdf and SCB-68 6225 & 6255 conn 1.pdf for connector 0 and 1 pinouts for the SCB-68.
Samantha
(4,273 Views)
