PXI
PXI-6255 to work with Visual Basic 4.0?
We are in the process of upgrading the laser and detection setup in our lab. But I don´t want to have to change the program so much (I know nothing of programing). We are currently using visual basic 4.0 on a XP windows computer. Is the PXI-6255 cards with DAQmx compatible with this system? Many thanks
(3,521 Views)
Hello Mirabelle,
in principle it depends on your program whether it able to communicate with the M-Serie cards like PXI-6255. But I suppose, if you are using VB 4.0 the programm is older, than the M-cards, so you will not be able to use it easy way to communicate with the cards. I even don't know what is possible with VB 4.0, if you able to call dlls, then you will also be able to communicate with card using the DAQmx drivers.
However in VB 6.0 it is possible. For this here are some links with examples.
-->http://digital.ni.com/public.nsf/allkb/735848148B5B4964862571F5004692C7?OpenDocument
-->http://digital.ni.com/public.nsf/allkb/B22FE2B0F9C8935286256E920073DA07?OpenDocument
But if you really do not know nothing of programming, probably the better way would be to get in touch with LabVIEW?
Kind regards,
Sergei
(3,511 Views)
Thanks for your reply. However, looking at it in more detail I have determined to just go ahead and write the whole program anew in LabView.
(3,494 Views)
This is surely not a bad idea :-). I think to learn/program LabVIEW is much more intuitiv than do it in Basic.
I wish you success with your application,
kind regards,
Sergei
(3,492 Views)
