PXI
PXI 6542 Buffer overwrite issue
I am using NI PXI 6542 which has 1MB per channel of buffer size. But after collecting 4096 data, the LabVIEW code throws error which says that buffer is being overwritten. Why is it so?
(3,399 Views)
Manojc,
There are several reason why an overflow may occur.  Could you please post some additional information about your application and if you could post the exact error code # from your test.
(3,391 Views)
