PXI
PXI-6542 The generation the continuous signal arbitrary form
Hello everyone !
I am started to study the PXI boards. Now I trying to know , how to use PXI-6542 just for generation the square waveform setting frequency.
Could you send or point to link me at the example, how to do it ?
Thanks advance!
(2,667 Views)
Since you're using an HSDIO card you will need to just push toggled data to the card, but you will have to stop and start operation to change the frequency. Otherwise, you can work off of what the solution to this post has for it's data combined with the Dynamic Generation example in LabVIEW's Example Finder to generate a pulse train with a constant frequency.
Mathew H.
(2,637 Views)
Thank you! It was interesting information
(2,623 Views)
