PXI
PXI 6682 Create CLock Route to CLK OUT
Hello All,
I am utilizing GPS as my timing reference on PXI-6682, I am attempting to Create Clock(unless there is a more transparent way to do this?) to generate a 1PPS synced with GPS and route it out the CLK OUT Front Panel connector on the PXI-6682.
I have done the same sort of thing in the past with the PXI-6682 and routed the 1pps to the back plane.  WHere I am confused is I don't see the CLK OUT as an option for routing when I browse perhaps the name is different?
thanks
John S
(3,532 Views)
Hi.
There are only 2 things that you can route to the ClkOut terminal in the PXI-6682: the 10MHz TCXO clock, or the 10MHz PXI_CLK10.  There is a nice block diagram of the routing capabilities of the board on page 3-2 of the user manual.
If you want to output some other clock, such as the 1PPS clock you are generating, you need to route it to a PFI terminal.
Hope this helps.  Good luck.
AlejandroZ
(3,529 Views)
Yeah that is what I thought I didn't want to use the PFI due to I was using 2 of 3 for timestamping events and if I use the third one it will need to be the combo IRIB/PFI0 but that is fine because we are using GPS as the timing refeerence not IRIG.
thanks,
JS
(3,527 Views)
