PXI
PXI-6682 as a network time server
I am working on a project that has a few different systems running.  One of the systems has a PXI-6682.  My system is built on PC104+ hardware and I need to synchronize my system with GPS time.  Is it possible to configure the PXI-6682 to act as a network time server?  If so I can set my system clock with GPS time from the other system.
thanks,
Bruce
(3,051 Views)
Hi Bruce,
I don't believe it will be possible to do it efficiently, as our device is not built to serve as a network time server.  The onboard clock is not accurate enough to achieve this type of operation.  We do not make a device that will act as a network time server, but there are other 3rd party devices that do support this function.
Kyle A.
Senior Applications Engineer
(3,036 Views)
