PXI
PXI-6683 can not be identified by Max
Hello
Who can tell me why NI Max can not identify PXI-6683 which was installed in a slot, I have changed the slot, but it seems not work (plus: NI-Sync 3.3.1, NI-TimeSync 1.1.2 and NI-Time Sync Plugin for Software have been installed)
(4,209 Views)
The only driver you should need to identfiy the PXI-6683 is NI-Sync. The version of NI-Sync you have installed was released prior to the PXI-6683, so that's why you're not getting support for the card. Can you try upgrading to a later version of NI-Sync? You'll need at least NI-Sync 3.4, but I'd recommend upgrading to the latest (15.0.1) if possible. You can find the downloads here.
(4,201 Views)
