PXI
PXI-6683H device error
I have a pxi system with the following devices PXIe-1071, PXIe-8840, PXIe-4492 and PXI-6683H. For reasons of activities I did not use it, and now that I am using it again it shows me an error in the PXI-6683H card, the curious thing is that no change has been made in the pxi system, which worked correctly. The error displayed by the MAX is the following: "Error-223805 occurred at Device Communication".
Does anyone have any information on how to solve this error?
(1,585 Views)
I have the same problem with NI PXIe 4112 (DCpower module).
Have you solved the problem?
(972 Views)
I hope the response is not too late. I solved the problem by reinstalling the driver for the PXI-6683H module.
Best Regards
Fredy
(728 Views)
