PXI
PXI-6722 sweep frequency step=1Hz
Does anyone use PXI-6722 to output sine wave under the below condition?
sweep frequency range : 18~20KHz
frequency resolution : 1Hz
My question is when I add 1Hz and the output signal doesn't add 1Hz, sometimes add 100Hz, sometimes add 200Hz.
Mason
(1,257 Views)
Please share the code you use to generate the sweep and scope captures of the generated signal.
Santhosh
Soliton Technologies
(1,240 Views)
Hi Santhosh,
Please see the attached file.
(1,197 Views)
  1. That is NOT the best way to generate a Sine signal
    • Use the highest ever sampling rate available and generate the signal (the task test panel is not the best way to validate this)
  2. Sampling rates are discrete, please refer to your device specification.
Santhosh
(1,190 Views)
