PXI
PXI-6733 Windows 10 Driver
I have a PXI-6733 and in NI-Max it says "Windows does not have a driver associated for your device".  What do i need to reinstall to fix that?  I tried reinstalling NIdaQ 18.6, but that did not work.
(2,189 Views)
Hello, can the article below be applied to your situation? There are some solutions when you find the message "Windows does not have a driver associated with your device" on MAX.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019PFISA2&l=en-US
(2,132 Views)
Hi there,
Can you provide a screen shot of Device Manager? Also, if there are any warnings there, can you right click on the device and take a screen shot of the properties screen? I'm like to see if you're having a similar issue to a user that posted here:
https://forums.ni.com/t5/PXI/Driver-issues-with-PXI-5404-and-PXI-5421/td-p/4016140
(2,124 Views)
