PXI
PXI-6733 and PXIe-6341 Status Code: -88705
I have the PXI-6733 and PXIe-6341 installed into the chassis PXIe-1073.
I have installed the software and drivers. the chassis is connected to the PC through the PCIe-8361.
While in the device manager everything seems to be installed properly, in the NI MAX I see the PXI-6733 and PXIe-6341 have an error signal with the error code -88705 that indicates the device to be not installed properly.
note that I have been able to use another board installed in the chassis without any problem.
Can you please advice on what can be the problem? I have tried to install and reinstall the drivers through the DAQmx but with no success.
Thank you,
Rani
(2,214 Views)
If it's not a driver's problem what can this be?
(2,179 Views)
Accepted by topic author ranibar
Ok I managed to make this work if anybody else might have a similar issue in the future
All I had to do is to reset the NI MAX configuration data which can be found in the NI MAX software under Tools.
(2,153 Views)
