01-31-2008 04:39 AM
02-04-2008 01:04 PM
01-06-2016 10:57 AM
I have experienced the same issue... any solution?
01-08-2016 03:10 PM
Hi anewsome,
Which devices you have connected on the controller? Did you try the steps that chris_amadasun suggest? Also, another step that maybe you would like to check is if the BIOS you have enable the option to boot using an USB device.
Regards.
01-08-2016 03:17 PM
I had this problem when I only had a monitor connected via DVI cable and no USB devices at all.
The boot from USB option is not enabled.
Adam
01-18-2016 04:25 PM
Sorry for the delay, Which OS are you using with the PXI controller? this is a known issue with the PXI 8106. And it was solved with a BIOS update, but the OS is important to troubleshoot the issue.
Regards.
01-19-2016 08:09 AM
I am using Windows 7
01-20-2016 11:27 AM
Hi anewsome,
Has the controller ever booted before? Windows 7 is not a supported OS for the 8105, though it has occasionally worked in the past. Additionally, what BIOS version are you using? Does the controller boot to the BIOS?
BeenCoughin
