PXI
PXI -8145 Ram Upgradation
i have purchased a new PXi-8145 controller, which is having 32MB flash ram. i need to upgrade to 128mb RAm. i have tried to getting 128mb Flash ram for local market and putting it to the controller without much sucess to get the full use of 160 MB ram. Please let me Know as what is wrong or how do i upgrade the controller for getting the full capabality of the 160 MB flash ram.
(3,379 Views)
A couple of notes:
1. The compact flash in the 8145 controller is used as *HARD DRIVE* storage, not RAM. If your application is failing to run because it is too large and not fitting in memory when executing, you likely need to upgrade your RAM, not your compact flash.
2. If you did in fact want a larger hard drive, you can do this, however you cannot use the secondary compact flash slot. You must replace your existing 32 MB compact flash module with the 128 MB compact flash module. The new module must be formatted with the FAT or FAT32 file system. When the module boots up, it should appear in MAX as an unconfigured controller. You can then assign it an IP address and install the software to it through MAX.
(3,378 Views)
