PXI
PXI-8176 in a pxi-1010 chassis locks up periodically
PXI 8176 processor locks up periodically during application operation. The configuration is as follows:
PXI-1010 Chassis 1
PXI-8176 processor
Slot 2: Datum bc635 irig timing card
Slot 3: MXI-3 card
Slot 4: Empty
Slot 5: 6071E DAQ card
Slot 6: 6071E DAQ card
Slot 7: 6071E DAQ card
Slot 8: 6071E DAQ card
SCXI portion:
Slot 1: 1163R Relay card
Slot 2: 1127 Switch card
Slot 3: 1127 Switch card
Slot 4 Empty
PXI-1010 Chassis 2:
Slot 1: MXI-3 Card
Slot 2: Empty
Slot 3: Empty
Slot 4: Empty
SCXI portion: All Slots Empty
VISA devices:
HP34401 DMM
HP 6
673 Power Supply
Other application specific facts:
TCP/IP communication wth a Client CPU over the 8176 ethernet port.
Fieldpoint device communication over the serial port.
During operation of the application, the processor hangs. If I attempt to close the executable, a message appears that "..the application cannot be closed. If debugging, close the debugging tool."
Timing of the hang is not consistent. The problem was first noticed while the Fieldpoint modules were being initialized (closed), but this only happened occasionally ( 1 out of 20 attempts). Since the application had not yet launced the DAQ portion of the program, the Fieldpoint controller was replaced.
Problem still persists, and has now also occurred during data acquisition, when Fieldpoint modules are not being accessed. Application was in Data Acquisition mode for 3.5 hours before the processor locked up. Is the MXI card a suspect, even though this has happened when MXI was not transmitting data?
T
he same application is used for a single chassis configuration, which has uses the same Datum time card and six 6071 E cards and therefore does not use the second chassis. We have not seen the lockup occur in that configuration.
Message 1 of 1
(3,173 Views)
