PXI
PXI 8187 controller boot problems and other
Accepted by SnowBoy111
Hi Haider,
For the PXI 6289, did you right click on the PXI chassis under Remote Systems in MAX and click on Find Devices?  If you haven't done that yet, it should bring up all the devices in the chassis.
As for deploying you VI to the Real Time Controller, you will first have to create a realtime project.  Then you will have to build a realtime executable and set that executable as a startup vi.  After that deploy it to your realtime target.
For the specific steps, you can go into the LabVIEW help and look for Real Time Modules in the index section of the help.  You can also do a search if you like for the same key words.
Hopefully this will help you get on your way.
Thank You,
Nick F.
Applications Engineer
Message 11 of 12
(1,273 Views)
hi
Now all the problems have been solved after installing DAQmx8.6.
Chassis PXI-1042  , contorller PXI-8187 and Card PXI-6289 ,  are indentified and test panel is running successfully.
but one problems now is VISA session for card PXI-6289 is not running
generating error
"Unable to open session to "VISA //192.168.40.2/ "
Return status code : 0xBFFF00A7
Status name VI_ERROR_MACHINE_NAVAIL
The remote machine does not exist or is not accepting any connection if th  NI-VISA server is installed and running on the remote machine ,it may have incompatible version or may be listening on a different port"
thanks
Message 12 of 12
(1,185 Views)
