PXI
PXI-8195 won't boot after installing LV RT 7.1.1
Dear all,
I just installed LV RT 7.1.1 on my RT Target.
Unfortunately after doing so I am no longer able to boot the Target.
It just stops after BIOS POST with a blinking cursor in the first line on the connected screen.
Changing to SaveMode in BIOS allows me to boot into save mode and to connect with the target through MAX
The following software is installed on the target:
- DataSocket for LV RT 4.2
- Intel 8254x Ethernet Driver 1.1.1.3.0
- LV RT 7.1.1
In another post I found that one is required to install NI-VISA and VISA Server. Is this correct?
I tried to do so but I am prompted with pending dependencies to NIINI 2.6. GREAT!!!
Next step will be to download an VISA update hoping to get rid of those dependencies?
Any input is appeciated.
Grüße
Phili
(3,365 Views)
Hi Phili,
which type of controller do you use? Does the system really has an 8254x Ethernet Chip
onboard or an additonal PCI/PXI-Board with this Chipset?
If you have no important software on the controller left (can be saved via FTP), you can
try to format the RT-Target in safe-mode by right-clicking in MAX ...
Regards, Thomas.
(3,337 Views)
Hello Thomas,
I indeed formated the real time target and reinstalled LV on my Host System.
Then I managed to upload software to the target and to boot it OK.
Liebe Grüße
Phili
(3,291 Views)
