PXI
PXI 8196 resetting due to system error
I have host PC connected to the RT PC with a crossover cable.  I could see all the PXI devices on the remote PC using MAX.  The problem I am having is that everytime I try to download a VI that calls the NI-DMM drivers, this resets the PXI-8196 controller during the downloading process.  I could download other VIs that doesn't calls the NI-DMM/NI-SWITCH drivers successfully.  I am lost to what is going on here.  Please advise how to solve this problem.  Thanks.
(3,011 Views)
Since the problem appears to be related to the DMM driver, I would first recommend reinstalling it on the RT controller.  If this does not work, the next step I would suggest is reinstalling it on the host computer, then reinstalling it again to the RT controller.
If you are still having problems after this, please post a reply with some more information about what software is on your system (including versions) and we can explore other options.
David H.
Systems Engineer
(2,977 Views)
