PXI
PXI-8360 interface motherboard issues....
So basically, when I install the PCI interface board on some computers, they will hang before the POST while on others, I can actually get into Windows to install everything.  Why is that?  I have to use older equipment that seems to work with these boards but that option will phase out once I no longer have access to older equipment.  Is there some master list of motherboards that are compatible with this interface??
Any and all help is appreciated.  Thanks!
(3,653 Views)
This can happen sometimes depending on the motherboard and the PC used.  There is currently no "Master List" that will tell you that a computer works or doesn't work with the 8360.  I can tell you that I have a Dell Precision 390 and have never had this problem.  I can also show you to the following documentations that may help you get up and running!
http://digital.ni.com/public.nsf/websearch/81CBF2F7F0BAEDBD86257330000514DF?OpenDocument
http://digital.ni.com/public.nsf/allkb/05B7131814A5DDA38625710F006BB098?OpenDocument
POst back if you have any other questions
Charley Dahan
Global Account Manager
(3,630 Views)
