PXI
PXI-8361 compatibility with PCIe-8361
I am setting up a new test station.  I want to use a new standalone PC, connected to an existing PXI chassis via copper cable.  My PXI chassis is already fitted with a PXI-8361 card (that had been previously used in conjunction with a PC fitted with a PCI-8361).
Most new PCs don't have legacy PCI slots, only PCI-express. Therefore I am planning to fit the new one with a PCIe-8361.
Will this be compatible with the PXI-8361, or will I need to upgrade to the PXIe-8361?
Dan
Dan
CLD
(3,262 Views)
A similar question that will answer your question: Will a PXI-8360 work with a PCIe-8361?
Short answer is that the PCIe-8361 will work with the PXI-8360 MXI Express interface.  See this bundle: NI PXI-PCIe8361
GCentral
(3,249 Views)
