PXI
PXI-8420
Can a PXI-8430/8 be used to replace a PXI-8420/8 in an automated test bench? I have existing software written in LabView for a PXI-8420/8 for which I do not have source code. I only have an execuatable.
(3,605 Views)
Hi bsexton,
The only thing you might have to change between the PXI-8420/8 and the PXI-8430/8 would be the ports.  Is the executable set up to allow you to select ports?  Otherwise the PXI 8420/8 is discontinued and the recommended replacement is the PXI 8430/8.
Andy K.
(3,596 Views)
