PXI
PXI 8430/8 Com Issue
Hi all ,
I Have a strange problem, with my 8430/8 PXI Card , In the begging I've entered it to slot 5 ,
The card was identified and set coms 3-10 to it's com ports.
Then I transferred it to Slot 6 and the card sets it's coms to 11 - 18 , and while doing so he did not deleted coms 3 - 10.
I've tries to change it manually thru the Device manager but the computer says the coms ( 3-10 ) are in use !
Any idea's ?
Kobi Kalif
Software Engineer
(3,775 Views)
Greetings,
Are you currently able to communicate with the card at all?
Product Support Engineer
(3,752 Views)
Yes ,
At first the device took coms 3-10 , then after location change it's coms are at 11 - 18 i can comunicate with it via coms 11 - 18.
Kobi Kalif
Software Engineer
(3,742 Views)
Can you see these ports listed in Measurement and Automation under Serial and Parallel? Can you post a screenshot of that screen? It might be that the system is looking for the disconnected module there.
(3,734 Views)
