PXI
PXI-8433 Transmitting Negative Numbers
I have a serial device to which I am attempting to send negative commands but I am having difficulties.  The device receives positive commands and processes them in a correct fashion but cannot interpret negative commands.  The protocol consists of 5 bytes - one lead character (one byte), one command character (one byte), two bytes for the command payload (data high followed by data low), and a checksum.  The payload requires two's complement and I have this coded.
Can anyone think of any reasons off the top of his/her head why I might be having these problems? (e.g. big endianness vs. little endianness?)
Jordan
Jordan McBain, PhD
LabVIEW Controls Engineer
Revolutionary Engineering
(6,237 Views)
When you say the device that cannot work with negative commands, do you mean the third party or the PXI-8433?
Which device do you have?
(6,214 Views)
I am certain at this point that the problem is with LabVIEW/PXI.  I can restate the question as follows: If I write a byte of 254 by itself to the serial port, the correct value is written to the serial line (as indicated by Versa-Tap serial spy device from Stratus Engineering).  If I write a U8 array with a value of 254 (FE) in it, the serial spy device indicates that 126 (7E) has been written to it.
This irregular behaviour only happens when I write a value over 127 as an element of an array to the VISA port.  I am not sure how I could write one byte at a time to my device and have it accept it but I am looking into it right now.
BTW: I am using LabVIEW 2009 SP1.
Jordan McBain, PhD
(6,211 Views)
If I put "ASRL End IN" and "ASRL End Out" to "none" (rather than Last bit), I can successfully write an array of bytes with a value like 254 in it.  My device, however, does not seem to recognize this.  The problem is with LabVIEW/PXI and not my device though - I feel fairly certain.
Jordan McBain, PhD
(6,209 Views)
Accepted by topic author JordanJMcBain
With "ASRL End Out" set to "None" rather than "Last Bit," I was able to write a byte array having values greater than 127.  I consider this very unusual behaviour and I suspect that it is a bug.
I would not have been able to resolve this issue without the Versa Tap serial spy device: http://www.stratusengineering.com/VersaTap.html
Jordan McBain, PhD
(6,180 Views)
