PXI
PXI-8513/2 Error 7 Qualifyer 0
I am currently setting up a system that involves the use of the PXI-8513 2 slot module and I was testing each slot via NI-CAN. The first slot passed the test but upon the second slot test it failed and came across the following error:
Error Code 7, Qualifyer 0
I only know that is a software error and have no clue as to what else that code entails. I have already restarted both the real-time controller and computer that uses NI MAX and am still having errors. I looked through all manuals related to the chassis and card itself to have no answers related to this issue so I thought that I would reach out.
Thanks.
Message 1 of 1
(1,267 Views)
