PXI
PXI-8531 will not boot
Hello everyone,
so I am using the NI PXIe-1073 with Ni PXI 8531 (slot 4 if necessary) and the PCIe-8361. I see those devices in MAX.
The problem is: When i start the NI PXIe-1073 (Power LED & LINK LED work) the PXI - 8531 does not work directly. The CANopen LEDs are off. So when I start a VI, I get the following error codes:
error -2147136878 and error -2147136764.
At this time there is a solid green and red LED at the CANopen LED of the PXI-8531. After I stop the VI, the PXI-8531 work normally with the same VI.
My Question is: How can I boot the PXI, so i can use it directly without any errors?
Grooving Greetings
Trixi
P.S.: When I boot the PXIe-1073 the PC start automatically. Is that normal ?
(3,499 Views)
Hi Trixi,
If you enabled wake on power on, yes.
Concerning the error messages, can you please check your bus termination?
Best,
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(3,411 Views)
Thanks for your reply.
What do you mean by that ?
Grooving greetings
(3,307 Views)
Hello Trixi,
what exactly don't you understand or have questions about?
Best,
Melanie
Melanie Eisfeld
(3,216 Views)
