PXI
PXI Controller reboot from MAX stopped working
I have a PXi-8196 controller in which periodically needs to be rebooted (will post another message on this issue).  For the past 8 months, I was able to reboot using MAX through the remote systems link.  In the last week, this method no longer works.  The controller goes offline, but MAX can not reconnect.   I have to physically power cycle the controller.  (The controller has a static IP configured.)
Does anyone have any ideas on what could be the root cause of the problem?
Thanks.
(3,822 Views)
Accepted by topic author ssto
Hi ssto,
Do you have a monitor connected to your PXI-8196? If so, when you choose to reboot your controller from MAX, what does the monitor display during bootup? Does everything seem to boot up correctly? Does it acquire its assigned IP address?
(3,806 Views)
I connected a monitor to the controller and can see what's going on in the system during the reboot.  On a failed reboot, the system doesn't seem to be rebooting at all.  It looks like it has lost internet connectivity.
Thanks for the help, the monitor provides good insight to what the system is doing.
(3,793 Views)
