PXI
PXI Controller upgrade
We currently run with the PXIe-1078 chassis and a PXIe-8820 controller. This controller is only compatible with Pharlab OS.
Pharlab OS was discontinued in 2021. In order to go to Windows 11 we need to upgrade to LabVIEW/VeriStand 2022 or higher.
Which means we need to change the controller to run with a different Real-time OS that is compatible with LabVIEW/VeriStand 2022 or higher.
I am planning to go for PXIe-8821 which can run on Linux Real-time 20 OS. What other consideration should I make to make sure the transition will be succesful?
I check the other cards in the system and they are all compatabile with the Linux OS
(267 Views)
All the CD we are using in in VeriStand can be rebuilt in linux x64
(265 Views)
You have covered pretty much everything.
  • Hardware has driver supported in Linux RT.
  • Custom device can be rebuilt for Linux RT 64-bit.
https://tmesystems.net/
(230 Views)
