PXI
PXI - NI PCIe-1427 -> device failed initialization -> Error: 0xBFF600EB
Hallo.
The last two days I tryed to grab an image from my NIR-Camera, by using the NI PCIe-1427 framegrabber. After installing the card into my Pc, installing the drivers and NI Software and starting NIMAX I get following errormessage:
The following IMAQ devices failed initialization:
Serial Number 0xFFFFFFF
Error 0xBFF600EB :
sometimes the Serial Number change to 0x0000000
The strange thing is, that this initialization worked for one time. I don't know what i had change to made it work. After one reboot the error occured again.
I hope therse someone who can help me.
P.s.: System Information:
Board: GA-G33M-DS2R
2,66GHz Core 2 Duo
2 GB Ram
Windows XP SP3
Max version 4.5.0f0
(3,720 Views)
I know this error. You can try to install the latest IMAQ Version to solve the problem (http://digital.ni.com/public.nsf/allkb/E7725A08B0E152628625747900627A3E).
If this doesn't solve the problem (this is most likely) you have to send your device to National Instruments for reparation. Please call 089 / 74 13 130 to get more information in case of the reparation!
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(3,704 Views)
