PXI
PXI NI5122 using Agilent VEE 8.0
I am trying to connect a NI 5122 using Agilent VEE8.0 .
The instrument address is PXI13::10
On config use :
Interface : NIDAQ
Driver Type : NI-SCOPE
Tried for Address both :
PXI13::10 and PXI13::10::INSTR
(3,822 Views)
Hello Xitaqua,
I am not an expert in troubleshooting from VEE but according to their manual, you are using the correct syntax. To confirm that is the correct name, I can help you see it if you create a support report of your MAX configuration and post it here. If you prefer, you can email National Instruments (ni.com/ask) and send it there.
I am assuming your NI-Scope driver version is 2.7 or later and that you can use test panels in MAX (just to make sure the hardware works correctly).
Finally, you can probably provide what error you are getting and if you have had any other problems with any other National Instruments hardware.
Gerardo O.
RF SW Engineering R&D
(3,812 Views)
Hello Gerardo,
I need to change the PCI Bus Address for the NI5122. It needs to be between 0 to 9 to work....
Do you know how that could be done ?
(3,808 Views)
Hi Xitaqua,
Seems like the Bus number is assigned on boot by the BIOS. Have you tied to place it on a different slot? If it is PXI, try a different segment of the chassis.
Could you post where did you find the information about the PCI Bus address needed to be changed?
Gerardo O.
(3,801 Views)
