PXI
PXI/PCI IGOR
Hi there
I have question concerning the MXI-4 Kit: Using that, can I just use my PXI modules as if they were PCI? The reason why I ask is that I use IGOR and wavemetrics makes no statement about NI PXI-Hardware.
Kind regards,
Florian
(3,176 Views)
MXI-4 is  a bus extender, so all your PXI or CompactPXI boards you will plug into the PXI-Chassis will be recognized by your computer as a PCI-board, and can be used in a normal way, as if you would have them plugged in directly into the PCI slot (as long as you have a windows driver of course).
(3,161 Views)
